TeamTalk
-   Engine / Drive Train (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=24)
-   -   How easy should the prop turn by hand (http://www.mastercraft.com/teamtalk/showthread.php?t=47153)
Chrisoswald 04-28-2012 08:14 PM
Have a 88 prostar and was curious to see how easy the prop should be to spin by hand when the boat is dry.
Thanks.
mikeg205 04-28-2012 08:15 PM
on my 95 it spins freely... how's the cutlass bearing look?
Chrisoswald 04-28-2012 08:39 PM
It looks good as far as I can tell. The prop take both hands to turn. I would classify it as hard to turn by hand for sure.
Jerseydave 04-28-2012 08:51 PM
There should be some drag when turning the prop so if you're use to an I/O or outboard it will spin way harder than those. There should be no up and down play in the bearing and the bearing material should look uniform all around the shaft.
If the boat has been on the trailer all winter and you're trying to turn the shaft it will feel extra tight until you run the boat in the water.
Chrisoswald 04-28-2012 09:31 PM
Thanks for the info. I had read some posts about being able to turn the prop with one finger and that seemed almost impossible to me considering the strut and shaft packing. I ran it for a long time Friday and no vibration and the packing nut never got hot so I think I'm properly aligned. May unbolt the coupler to see if I'm aligned properly.
FrankSchwab 04-29-2012 12:40 AM
1 Attachment(s)
Posting the obligatory "How to correctly align your propshaft once in the boat's lifetime" doc.
Do it once, and you'll be able to rotate the prop with one or two fingers. I can do it with one, but it hurts. Two is a more reasonable measure on mine. It made a significant difference in smoothness when I did it.
Needing two hands suggests to me that you should do this.
/frank
CantRepeat 04-29-2012 04:58 AM
Once aligned correctly you should be able to spin the prop with one finger.
Chrisoswald 04-29-2012 09:17 AM
Thanks a million guys...im off to align...wish me luck!!!
93ProStar205 04-29-2012 09:22 AM
My 87 poweslot was always rather stiff. Almost a two hand deal, but fine when in the water. Certainly an alignment check won't hurt.
Chrisoswald 04-29-2012 09:22 AM
wow..i just read that document..seems like a bear to do
