TeamTalk
-   Engine / Drive Train (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=24)
-   -   350 mcx thermostat (http://www.mastercraft.com/teamtalk/showthread.php?t=51136)
munkymush 09-30-2012 06:18 AM
350 mcx thermostat
hi,can anyone tell me about the 350 mcx thermostats. when i replaced mine recently with a new 160 deg.. i noticed theres a fairly deep circular recess where the stat fits ? and i was wondering if the stat should have a sealing ring or something there ?? to stop water bypassing the stat?
medicmoose 09-30-2012 07:24 AM
There should be a black rubber ring around the largest diameter portion of the t-stat.
munkymush 09-30-2012 08:13 AM
hi thanks for that .. mines never had a seal on it and the new stat didnt come with one from mastercraft either.. does anyone know the part number for this seal ? thanks glenn
mikeg205 09-30-2012 10:13 AM
If you can't find the rubber gasket you can try this stuff ...
http://www.permatex.com/products/Aut...sket_Maker.htm
Hey Medic..was this the what the gasket looks like on the MCX t-stat? below?
http://www.skidim.com/prodinfo.asp?number=RP026002F
medicmoose 09-30-2012 12:05 PM
It's been a while since I looked at the MCX t-stat...but that seems to be what I recall.
CantRepeat 09-30-2012 12:49 PM
I would go with the correct part over the permatex stuff.
