TeamTalk
-   General / Other (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=25)
-   -   Steering (http://www.mastercraft.com/teamtalk/showthread.php?t=55101)
Redstorm 06-13-2013 12:18 AM
Steering
I have 2001 205V and the steering is stiff under power. It turns fine when throttled down. Is this the cable or something else? If the cable, should I swap it with new since the boat is 12yrs old? Thanks in advance!!!
FlyHighorDie 06-13-2013 11:25 AM
I replaced mine on my 209 and I needed to use two hands to steer. I replaced the cable and it turned with one finger. You could check the end of the cable where it attaches to the rudder and possibly clean it up and regrease it to see if there is any improvement. Look at my Thread and see if your cable looks as nasty as mine. Also my boat is a DD so it may be a little different procedure than yours. As far as getting to the rudder Etc.
http://www.mastercraft.com/teamtalk/...t=53412&page=2
Bob B 06-13-2013 11:42 AM
See this
Originally Posted by Bob B (Post 893091)
Conversation I had with Peter this spring:
Hi Bob, I am sure there is meant to be a white nylon washer about 1/8" thick and 2"diameter between the rudder and the port. ie. Put washer on shaft then slide rudder in from underside. I gather you are still experiencing problems. Have you actually had your rudder completely out yet? Because I found mine was caked with dry grease up in the port, and once cleaned out I could get grease to ooze out of the little hole about the size of a pinhead underneath. Curious does yours have the winged rudder or not? Cheers, Peter
Peter, I decided to grease the rudder again, it finally took some grease. Looked under the boat (on a lift) and saw a fine string of grease. Took the boat for a drive, no binding
e. Grease was not getting to the rudder.
MI_Corey 07-06-2013 07:23 AM
How much grease should be on the rudder shaft when you drop it out? I'm still having steering problems with my '93 Maristar after replacing the steering cable and greasing. With the steering cable disconnected the rudder turns very free. Also, the steering is only hard under power. I dropped the rudder and the shaft had just a little grease on the bottom of the shaft and a little on top. I haven't removed the rudder box yet but running my finger inside it it feels smooth and lightly greased. That said, when I grease it with a gun, no grease ever comes out of the weep hole. Still, it makes me think the rudder is not the culprit to my hard steering. Could the box under the steering wheel ( I don't know what it's called, maybe helm? ) that you feed the steering cable into be bad? Any help would be appreciated as my wife has a hard time driving our boat right now and I would like it to be right anyways.
MI_Corey 07-06-2013 03:43 PM
Called my dealer today and they basically told me to expect the steering to be hard in a maristar. I'm not buying that. I will continue to plug away at this until I get it right.
Redstorm 07-11-2013 03:23 PM
Update....cleaned and greased the rudder shaft. Steering is like new again! What a difference! One finger steering!
MI_corey.....is your steering easy when on the trailer or at a stop? If so check your rudder shaft. If it is stiff it on the trailer it is most likely your cable.
