TeamTalk
-   Underwater Running Gear (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=66)
-   -   Just bought an OJ prop (http://www.mastercraft.com/teamtalk/showthread.php?t=50877)
CC2MC 09-13-2012 09:28 PM
I just purchased an OJ 13x13 4 blade prop for my 94 prostar 205 off ebay. It will not get here until next week and hopefully I will be able to put it on and try it out. I am not sure how much difference I will be able to see until I get the ballast bags set up. Does anyone that has this setup have any good info as far as noticeable differences?
Should it have a better low end?
How much top end do i sacrifice (not too concerned, but curious)?
Will it hold a constant speed better?
I did send an email to Eric Johnson and he said that this will be a very good overall prop, but that is about all I got out of him.
Spork 09-14-2012 12:28 AM
I have that prop and overall its very good hole shot, no loss of max mph and does hold rpm and mph better than the old 3 blade. But I don't run any ballast so no info on being loaded down.
Double D 09-14-2012 08:06 AM
I have the same set up. Moved from a 3 blade. Here are my numbers before and after.
Boat Speed Test:
3 Blade Prop
1st Start = 9.09
2nd Start = 8.5
3rd Start = 8.7
Top Speed = 41.2
New
4 Blade Prop
1st Start = 8.32
2nd Start = 8.0
Top Speed = 40.8
Of course this was not professionally done. Loading on trailer is better too.
Sent from Never Neverland using my iPhone 4 on Tapatalk
Traxx822 09-14-2012 09:37 AM
I just got my new OJ prop this week. Eric suggested 14.75 X 15.5 LC 1 1/8" 4-blad.
All I can say is HOLY HOLE SHOT.
I have a 200V with lots of ballast and it feels like I launched with my old prop (13x13 4 blade OJ) with no weight in the boat at all. Sacrificed top speed but with ballast in I can't go over 32mph anyways or it porpoises to bad.
So in other words I just upgraded to a bigger prop from the one you just bought. The old prop I had was good but this prop takes the cake if you have weight.
BrooksfamX2 09-14-2012 09:57 AM
Originally Posted by Traxx822 (Post 877604)
I just got my new OJ prop this week. Eric suggested 14.75 X 15.5 LC 1 1/8" 4-blade............
Thats the one I want to get for next season..........:)
GoneBoatN 09-14-2012 10:48 AM
Why would you want to go at a higher speed with ballast? Other than to excessively burn gas. :D
I have that on my X-15 with an MCX. As mentioned before, hole shot is nice. However, I'm only using stock ballast. Engine tops out at the upper end of the recommended RPM (4800) at WOT. I have a spare of the same so if we end up at Shasta at the same time again next year you can demo mine if you want.
CC2MC 09-14-2012 11:20 AM
Well Eric also told me that If I plan on adding more than 2000 lbs of ballast he would suggest the 13 X 11 LC 1" XMP 3-blade. I believe Acme recommended a 13x 12 4 blade prop.
Thanks DoubleD for the numbers.
BrooksfamX2 09-14-2012 12:48 PM
Thanks for the offer. I currently have a 13.7x15.5 (came with boat) and it works OK. I have not hit the rev limiter, but can easily run 5000 rpm plus.
I dont cruise with ballast full. Like at Shasta we cruise to our spot, fill, play, empty, cruise back.....
We are there same time next year.
GoneBoatN 09-14-2012 01:08 PM
I figured there was a reason Eric recommended that prop. :cool:
CC2MC 09-18-2012 10:41 AM
I got the prop yesterday and I decided to polish it up a little bit. You have to love Mothers Metal Polish. It still needs a little work to be nice and shiny, but then again who will really see the thing? I found out my neighbor also has a prop puller for his SN that he will let me borrow, so that is one less thing for me to have to purchase. It is nice having a neighbor with that same interests as me, even though he is nearly 20years my senior.
