TeamTalk
-   MasterCraft In Your Area (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=8)
-   -   Repair place for inboard engines in Richmond, VA? (http://www.mastercraft.com/teamtalk/showthread.php?t=57528)
MCBoatGirl 09-22-2013 12:30 PM
Hello,
Anyone had a good experience with a shop that works on inboards in Richmond VA? I hear the closest MC dealer is in Charlotte.
Thank you!
nascar 09-22-2013 01:10 PM
try Joe Thompson at Inboard Marine in Wilson , NC 252-2370616 should be a little over 2 hours from you .
waterlogged882 09-22-2013 01:22 PM
MCBoatGirl 09-22-2013 02:23 PM
Thanks, it's not for winterization. I have to repair the shaft (bent) and get it reinstalled. I have having trouble getting the cuppling off the shaft. Even if I end up getting that off myself I think I would prefer to have someone else re-assemble everything.
waterlogged882 09-22-2013 02:42 PM
SteveM 09-22-2013 08:33 PM
I'm not sure about Richmond, but there is a place at Lake Anna called The Boat Shop. Their number is 540-895-9616, ask for Rob. I've only used them for parts, but have heard good things and can definitely say he's saved me a few times when I needed a part or some advice. It might be worth calling him to see if he could help you out. Probably would be about an hour from Richmond.
MCBoatGirl 09-23-2013 10:52 AM
Thanks, I am looking for a local resource for when I have issues. I am working through the shaft situation slowly with the advice from boat owner friends and this forum, but I know there are going to be times when I need additional help and will need to take it somewhere. Just looking for solid references for local resources.
