TeamTalk
-   Audio/Stereo (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=53)
-   -   Help with a new sub box please (http://www.mastercraft.com/teamtalk/showthread.php?t=72971)
SpokaneSteve 05-03-2016 10:33 PM
2 Attachment(s)
Hello all:
I could use some advice on rebuilding a sub box:
Here is the old sub box:
Attachment 142750
Attachment 142751
Should I try to repair this and seal it with a marine epoxy?
Should I build a new one out of HDPE board? Something else?
All advice appreciated!
Thanks much, Steve.
bet_on_black 05-03-2016 10:37 PM
Start new, use birch plywood, coat with epoxy/bedliner, and add feet to lift it up and keep it dry.
SpokaneSteve 05-03-2016 10:46 PM
How thick of plywood? 1/2 inch or 3/4?
Thanks much. I want to get this done this weekend.
Steve.
MLA 05-03-2016 10:48 PM
Nothing there to repair, sorry. Yes, start fresh, but HDPE is not needed. Construction methods will get you more likes than the material used. That enclosure looks 100% raw on the inside and may a poor coating of something on the outside.
dvsone79 05-03-2016 11:14 PM
Steve.
3/4" MDF seems to work best for car stereo applications, so I would imagine the same thickness would be best if you're using plywood.
I used 3/4" MDF and sealed it inside and out with 3 coats of polyurethane, then carpeted it and used rubber feet to get it raised off the floor. Been going 3 years strong now.
SpokaneSteve 05-04-2016 05:17 PM
A couple final questions
OK - my local wood shop only has 3/4 inch marine fir plywood.
Is this acceptable? It's got to be better than MDF right?
Second, what type of sealing liquid should I use? West Systems epoxy, polyurethane, or something else?
Thanks very much for all the help!
Steve
bet_on_black 05-04-2016 05:35 PM
Steve
That plywood and epoxy will be awesome, and lightyears ahead of the MDF. Put some plastic feet on that bad boy and you'll be set.
Oh, and glue and screw everything together. Caulk the inside seams to keep it air tight.
lees23 05-04-2016 06:48 PM
What kind of sub was in there?
SpokaneSteve 05-05-2016 02:15 AM
1 Attachment(s)
JL 13W1v2-4
Attachment 142816
strangely it has a smaller amount of enclosed space than the old sub. Hopefully I can get close.
Steve.
SpokaneSteve 05-12-2016 09:49 AM
I'm no cabinet maker....
1 Attachment(s)
OK - here it is:
Attachment 143236
3/4 inch marine plywood - three coats of West systems epoxy in and out, starboard spacer to keep it off the carpet.
Wish me luck - it goes in tonight!
Cheers, Steve
