TeamTalk
-   General / Other (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=25)
-   -   Throttle Safety Collar is Stuck on my '07 (http://www.mastercraft.com/teamtalk/showthread.php?t=50553)
Boobaychap 08-28-2012 02:20 PM
1 Attachment(s)
The throttle safety collar on my '07 Maristar 215 SS is stuck in the up position--will not lock in neutral.
This is real safety issue because the boat can go into gear if you inadvertantly bump into the throttle while in neutral.
I believe this to be a corrosion problem and want to disassemble the throttle and inspect & lubricate it.
I'm looking for a manual with an exploded diagram. Picture of the throttle follows.
Can anyone identify the make and model or provide a link to the manual? All advice appreciated.
Thanks,
Boo Bay
milkmania 08-28-2012 04:08 PM
Thanks,
Boo Bay
only have knowledge of my 91
but, the ring had a connecting rod that went down the shaft to a pivot block... there was a spring around the shaft (can't remember whether spring was at top or bottom of rod)... the block pivoted in and out of a notch at the rotating part (forward and reverse)
disassembled, lubed it, added a stronger spring and reassembled
edit:
seems like the maker was Teleflex
look at page 10
http://www.teleflexmarine.com/wp-con...ion_manual.pdf
